fuel injectors bad?
Old Aug 27, 2010 | 10:59 AM
redsped17's Avatar
fuel injectors bad?
I have a 1986 Camaro z28 that will not run. it turns over and will run off ether, but not off of regular gas from the fuel system. I have pulled the Injectors and they are extremly dirty (almost a rust color and the o-rings are shot) I put an ohm meter on them and I dont have a single one below 17 a few seem to jump around anywhere from 17 up to about 25. are these bad? is there something else I should check? Thanks in advance for any info.
Old Aug 28, 2010 | 01:42 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: fuel injectors bad?
should be getting readings like 0.013-0.017 ohms. One that is 0.002 is a bad one!
Old Aug 28, 2010 | 08:29 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Check your fuel pressure. If it's around 43 PSI then, yes, I'd vote for the injectors.
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Bryan F
Aug 18, 2015 02:28 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
