85 camaro carb 305/350 into a tpi?
Car: 85 Camaro Berlinetta
Engine: 2.8 V6
Axle/Gears: stock
Hello All
I had a question can you take any 85 camaro 305/350 carb and turn into tpi is this possible i am new to this and i want to buy 305 or 350 build it for my 85 v6 camaro also my 2.8 is fuel injected so if i wanted to go with 305 or 350 carb could i make that switch and pass smog emissions in california?
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: 85 camaro carb 305/350 into a tpi?
It is possible, but there is more to it than just swapping motors, the tranny needs to be swapped too, for what it's going to cost you could hunt down a decent third gen with a 350 already in it.
Engine: 2.8 V6
Axle/Gears: stock
Yeah that was the plan to find a thirdgen camaro with a 305 or 350 but i didnt have any luck my budget was 1,000 for one and i found this v6 with the body is straight not crash no dents got it for $250 the only thing that was bad was the owner drove it with lil oil and mess up the crankshaft berings with the oil pump and when i turn it on u could hear a knocking inside the engine so i am almost done with the engine rebuild with performance parts to give more of a kick then up grade my gears to 3.73
84z96L31vortec
Aug 20, 2017 12:16 AM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
