1988 iroc smog pump delete, etc.
Old Sep 1, 2010 | 03:06 AM
chrkevjac09's Avatar
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
what do u guys think about a smog pump delete, a/c delete, and a EGR block off plate on a 1988 iroc? Has anyone done this and how did it work out for you?
Old Sep 1, 2010 | 11:48 AM
alek72us's Avatar
Car: 1991 Camaro z28
Engine: TPI 350
Transmission: Auto 700-4r
Axle/Gears: 3,23
re: 1988 iroc smog pump delete, etc.
if u can get away with running with out smog do it. u dont need ur a/c so u can get rid of that. on ur egr valve i think u need to get rid of that in the computer first or ur car wont run good. but i could be wrong.
Old Sep 1, 2010 | 11:49 AM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
I did a smog delete and really aw no difference. Order a 1LE pulley and smog delete pulley for about $80. I'd leave the egr because your fuel economy will suffer without it, but it's your choice.
his thread has pretty much everything covered for find the sometimes elusive pulleys.
https://www.thirdgen.org/forums/faq-...lete-smog.html
Old Sep 2, 2010 | 11:57 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 1988 iroc smog pump delete, etc.
You live in California. We have to pass emissions tests here. Its totally illegal to remove or disable any emissions device on a street driven vehicle in all 50 states, even if your state doesnt do emissions testing.
My car makes this much power and passes the emissions test. Why bother being illegal?
Old Sep 3, 2010 | 01:49 AM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
I dont care about emissions man i got people that pass me i just think it's a waist of space....I dont no yet im still thinking about it.
Old Sep 3, 2010 | 01:07 PM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
move to IL no emissions testing or inspections for anything older than 97
Old Sep 3, 2010 | 01:29 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
We don't have emmission testing in Alabama. I did the smog pump delete when my smog pump locked up. Don't look for power gains because I don't really think the pump is a much of loss. The engine compartment is a lot cleaner without it it though.
I would say keep the AC. If you sell the car and you removed the AC it will lower the value of your car a few hundred dollars. you can take all that stuff off, and put aluminum heads on and see a nice weight difference however. It if you aren't going road racing or auto X ing it isn't going to make a lot of difference. If you are already in the low 12's or something like that, it might be a more appropriate change. I just don't think weight reduction on a low 14 second/high 13 second street car warrants this.
Good Luck.
italiano67
Dec 11, 2016 09:21 AM
actionj
Carburetors
Aug 16, 2015 09:51 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
drathaar907
Aug 6, 2015 04:20 PM
