Plumbing in MAP sensor
Old Sep 3, 2010 | 04:34 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
How difficult is it to plumb in a MAP sensor to a MAF V8 TPI plenum?
I cant find any pics of the MAP plenum with sensor looks like up close to get an idea.
Old Sep 3, 2010 | 10:35 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Plumbing in MAP sensor
The MAP plenum has a mount at rear for the MAP unit.
SEE
http://www.hotrodlane.cc/Streetstories/choosingtpi2.htm
MAF plenum doesn't so you need to make a custom mount and run a vac line from one of the TPI plenum ports. Preference is keep vac line as short as possible so MAP response is better
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
wstephan96
Sep 25, 2015 04:28 PM
