almost there! (pics)
Old Sep 6, 2010 | 09:51 PM
Skyshadow's Avatar
Car: 89 Trans AM GTA
Engine: 5.7 V8 TPI
I almost got my car completely ready to drive but i need to fix two things. I get a code 32 and code 15 on the check engine light and i need help fixing that. the code 15 is for the temp gauge wire (long wire coming from behind drivers side head pic 1) and it connects to a sensor under the drivers side head. i need to know if this is the right wire and if so what connector i need to buy to replace the butchered one.
The second code (32) means something is up with the EGR. I know it is hooked up to some vacuum lines (pic 2) but im not sure how these lines hook up. here is a picture of the two open lines on the car(pic 3) I also think it is supposed to hook up to a solenoid behind the distributor but i cant seem to find it(maybe it was removed) I need to fix this EGR problem so if anyone knows how to or how to disable the EGR properly (is that a good idea?) I would really appreciate it.
also guys please bare with me and my currently small amount of knowledge with cars cause Im young and still learning. thanks
Old Sep 7, 2010 | 02:00 PM
Skyshadow's Avatar
Engine: 5.7 V8 TPI
Re: almost there! (pics)
anyone know anything about this? I appreciate the advice so far its really been helpful to me since Im still young and don't know that much about engines.
Old Sep 7, 2010 | 02:02 PM
Maeryk's Avatar
Car: 89 Formula 350
Engine: 355 long block TPI
Transmission: auto
Axle/Gears: Richmond 4:10 Eaton Posi
Does your car still have the emissions label on the fan shroud? if so, it should (maybe?) show the vacuum routing.
Old Sep 7, 2010 | 07:55 PM
Skyshadow's Avatar
Engine: 5.7 V8 TPI
no i dont think it has that label anymore
Old Sep 9, 2010 | 12:43 PM
Skyshadow's Avatar
Engine: 5.7 V8 TPI
anyone have answers on how i can fix this?
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
