was there a difference from 88/92 TPI intakes??
Old Sep 8, 2010 | 09:12 PM
DEAD SPACE's Avatar
I found a 89 complete car with a TPI motor. Was therte a difference from the newer TPI?? If I remember correctly I think I was told the 90/92 tpi unit setup were better, but dont remember why LOL.
Someone please correct me!!
Old Sep 8, 2010 | 09:18 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: was there a difference from 88/92 TPI intakes??
the 90 TPI ECU is a quicker 256K prom. speed density no MAF, timing map inside the Prom
compared to 128K prom 89 under
the TPI system is identical minus TPS and no cold start INJ,
Old Sep 8, 2010 | 09:25 PM
DEAD SPACE's Avatar
Could I just find a 90 n up ECU and use that?? I was going to install a holley stealth ram.
Old Sep 8, 2010 | 09:37 PM
88gta3508's Avatar
Engine: 231 / 383
you would need the 90 Harness or re - work the 89
WAY better Choice
if your purchasing the HSR!!!! your good to go
you will need rails & lines everything eles will swap over
No EGR check your States Emissions <<<<<<
Old Sep 9, 2010 | 03:33 PM
DEAD SPACE's Avatar
WAY better Choice
So with the HSR I dont really need to worry about using a 90/92 computer or harness??
Old Sep 10, 2010 | 10:14 AM
DEAD SPACE's Avatar
I take it that a 89 formula 350 is a 350 CI motor right??
Old Sep 10, 2010 | 11:07 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
i don't know if this makes any difference but i have a tpi intake from a 89 5.7 gta and a tpi from a 91 z28 5.0 and on the front of the intake where the coolant temp sensor is, there is only one hole for the temp sensor on the intake from the 5.0 z28 and on the 5.7 trans-am there are 2 holes.
so there is one difference
1992rs/ss
Jan 31, 2025 05:10 PM
evilstuie
Jan 9, 2020 08:29 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
Jake_92RS
Aug 11, 2015 10:39 AM
