all 4 Passenger side fuel injectors don't pulse
Old Sep 10, 2010 | 09:58 PM
mandre74's Avatar
Car: 91 GTA
Engine: L98 350 TPI
Transmission: TH-350
Axle/Gears: 3:23 posi gears
91 GTA 350 all 4 passenger side fuel injectors don't pulse, power on both wires going to injector. if one bank of the ECM isn't firing could there be a fuse blown for that bank and if so where would it be? or is the ECM just fried and needs replaced or can you just replace the one driver board thats fried?
Old Sep 10, 2010 | 11:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: all 4 Passenger side fuel injectors don't pulse
Originally Posted by mandre74
. if one bank isn't firing could there be a fuse blown for that bank
Yes or if one injector shorted will take whole bank down
Disconnect one injector in the dead bank at a time and see if others fire
Check injectors resistance.All should be the same
Old Sep 10, 2010 | 11:25 PM
mandre74's Avatar
Car: 91 GTA
Engine: L98 350 TPI
3 injectors read 16.9 and one 6.9 even with it unplugged the other 3 still don't work
Old Sep 11, 2010 | 12:58 AM
mandre74's Avatar
Car: 91 GTA
Engine: L98 350 TPI
I feel dumb now, inj fuse was blown, i know i checked it once i don't know, I guess that is what i get for working with budweiser thanks vetteoz.
Old Sep 11, 2010 | 09:05 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
you still need injectors. The one at 6 ohms is shorted. It will keep blowing fuses or fry you ECU,
Old Sep 11, 2010 | 04:19 PM
mandre74's Avatar
Car: 91 GTA
Engine: L98 350 TPI
ya i plan on getting some new ones when i put the new BBK intake on and looking at a turbo that goes under the trunk area in place of the muffler and run the intake up from there rear to it.
Ikes 91Z
Dec 9, 2015 03:49 PM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
