hard starting runs for awhile dies and wont start
Old Sep 14, 2010 | 01:36 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
alright well for awhile now my camaro has had a problem of hardstarting it has to crank for awhile to finally start once it starts it runs fine for awhile if your dirving youll lose power and will have to keep your foot on the pedal to stay running and once it dies which is inevitable. It wont start back up for awhile.
dont know if it matters but its a l98 converted to a 5 speed with a chip and vats delete.
It has new plugs wires cap and rotor bug. and bosch III injectors and seals.
Old Sep 14, 2010 | 01:50 PM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
Re: hard starting runs for awhile dies and wont start
What is your timing set at? How about the TPS? How old is the O2 sensor and CTS?
Old Sep 14, 2010 | 02:47 PM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
timing is set to factory. Tps from what I know the sensors have 162k on them cant be curtain
Old Sep 14, 2010 | 06:47 PM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Well I bought a fuel pressure tester and I'm not getting any fuel. The pump isnt priming. I switched one of the fan relays with the fuel pump relay and still nothing is there anything else to check before replacing the pump.
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
