tpi runners.
Old Sep 21, 2010 | 12:14 PM
pestrada38's Avatar
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
tpi runners.
I have a 305 tpi and i want to get new runners. Which ones are the best . The SLP or Edelbrock. And if i get 22lbs fuel injectors would it make a difference?
Old Sep 21, 2010 | 01:35 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: tpi runners.
Depends. Out of the box Edelbrocks as long as they are machined correctly. For serious modification SLP.
Old Sep 21, 2010 | 02:13 PM
383tpimachine's Avatar
Car: Corvette
Engine: 383
Axle/Gears: D36 w/ 3.08
Re: tpi runners.
What are the stock injectors?
Injectors can help if yours are worn and the newer bosch III have better spray pattern atomization than stock.
going to a bigger size needs a tune.
Old Sep 21, 2010 | 04:37 PM
pestrada38's Avatar
Re: tpi runners.
19lbs
Old Sep 21, 2010 | 05:07 PM
Stephen's Avatar
Car: 87 GTA
Re: tpi runners.
MAF will allow a little more leeway for mods than MAP will, before PROM tuning is needed.
Old Sep 21, 2010 | 06:07 PM
Car: Corvette
Engine: 383
Re: tpi runners.
Maf will think its feeding with 19lbers when its really dumping more in with 22s
I ran PIG RICH when I didnt get a tune for bigger injectors. I balanced it out for a while with an AFR but still ran rich.
Got a tune and been happy since
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
