Idles at a different RPM everytime its started
Old Sep 21, 2010 | 11:38 PM
bigmike87's Avatar
Car: 1989 Camaro RS
Transmission: T-5 5 Speed
just a quick question, my 87 Iroc likes to call the shots on where it wants to idle. I usualy try and run it at about 700-800 rpm (305 TPI) so i will set it drive it shut it off then it wont idle so i bump it up drive it shut it off then it idles at 2000 rpm. then ill drop it back to 700 drive it shut it off and wont idle and so on and so fourth in that viciuos circle. im thinking it the IAC? just wanna verify before i purchase a new one, P.S no codes being thrown. thanks everyone.
Old Sep 21, 2010 | 11:42 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: Idles at a different RPM everytime its started
You need to get it on a scanner/datalogger to find out what the IAC counts are doing..
and what the commanded RPM is..
That said, id start by removing the IAC and the IAC housing from the throttle body, and cleaning them very well, then reinstall and set minimum idle again...
if it still persists, its either the IAC, or the programming.
specialized
Jun 18, 2022 09:26 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
