cylinder heads
Old Sep 22, 2010 | 06:55 PM
91z28blue's Avatar
Car: 1991 z28
Engine: 5.7l TPI
cylinder heads
Hi guy...
i am looking at doing up a new engine for my 1991 z28
i have just been thinking of what way to go, 350, 377 or 383... now i want to spend as little money as i can with this one.. so what i have done is got some part together and i am not to sure on heads...i have a set of l98 aluminum heads at my work off a corvette (10088113 casting number) but my boss has told me that there are not a good flowing head, he tolded me to look for 14101128 casting... can anyone tell me some more about the two heads or should i just find something else... i know that the 10088113 have 163 runners,58cc, I 1.94,E 1.5 or i am wrong with that?
thanks
what i have now for parts are
tpis miniram intake
zz4 block
6" rods
good piston with total seal rings
22lb and 24lb injectors
i have 3 cam shafts but have not picked on since i have not yet pick total engine size
Old Sep 23, 2010 | 06:40 AM
91z28blue's Avatar
Car: 1991 z28
Engine: 5.7l TPI
Re: cylinder heads
ttt
Old Sep 23, 2010 | 06:54 AM
InjectorsPlus's Avatar
Former Sponsor
Re: cylinder heads
Those heads will be go to about 350-375 CHP.....
If you're goals are less than that, you have no problem.
I have a special on Profiler heads, an EXCELLENT head, as good as anything out there and 100% American made. $950 a set.
It would be good to have more breathing room on top, they would certainly help, however if it's not in your budget and your HP goals are less than 350 CHP, I wouldn't worry about it, use those heads.
your injectors will be light I'd like to see you in 30s. Let me know how I can help you with that when the time comes.
Old Sep 23, 2010 | 11:12 AM
91z28blue's Avatar
Car: 1991 z28
Engine: 5.7l TPI
Re: cylinder heads
thanks for the info...will be looking around your web site soon
Old Sep 23, 2010 | 02:29 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: cylinder heads
What are your goals? You building a track toy or something you drive daily?
You are right on the dimensions; those heads are not impressive at all in that regard, almost identical to stock 305 heads. Stock "416" 305 heads are 160cc in runner, 55cc chamber, 1.85in, 1.5ex.
Don't expect anything great in stock form. Their best feature, other then the metal they are cast in, is the exhaust runner. Don't pay too much for them.
InjectorsPlus what is this combo that will give you 375hp at the crank?
Old Sep 23, 2010 | 05:07 PM
Former Sponsor
Re: cylinder heads
IDK off the top of my head, but I do have a disk with 10,000 dyno runs that have been documented for both BBC and SBC I can look there if you want. Gives the complete breakdown.
If you're asking me to spec an engine, there's not enough information here as to what the OP wants to do and I'm not an engine builder. I have focused my experience and knowledge to fuel systems, and head design. Not to say I haven't built engines, but when I have these discussions with customers, we never talk about building to a dyno number. We talk about building to a spec.
In this case it's going to be all about the cam, and I defer to Bullet's advice based on the desired result. They nail it every time and they know what they are doing.
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
