air bubbles in fuel rail
Old Sep 26, 2010 | 10:59 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
My car surges and ive tried alot of things already. I can tell you for sure there are no vacuum leaks and the ignition system is perfect and egr is blocked off. I think there are air bubbles coming through my fuel lines because if you listen close to the return and feed lines you hear a noise that sounds like when you turn the key and the fuel pump primes. It sounds like something rushing through the lines but you hear it off and on, its not a smooth consistent sound. When I check the fuel pressure and i release the pressure I see the bubbles in the drain hose. what could cause this?
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
mdtoren
Aug 23, 2015 12:52 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
