roller rockers
Old Sep 28, 2010 | 08:30 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
roller rockers
I have a 90 gta engine in my IROC.......
question ...If I go with true roller rockers...do need to use valve guides?
Seems when I was putting the engine together I tried some but they did not seem to stay on top of the springs...would slide to one side or the other.
Or did I have the wrong ones...can't remember what brand they were now, was awhile ago
Old Sep 28, 2010 | 09:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: roller rockers
You sound very confused
Valve guides are the things in the head that valves run
Only touched when head rebuilt.
Are you talking about GUIDE PLATES???
They fit under the rocker studs and align the pushrods
You only need guide plates if you are installing non self aligning rockers ( of any type )
Old Sep 29, 2010 | 05:30 AM
gscz28's Avatar
Car: 89 iroc
Re: roller rockers
guide plates is what I meant...thx
Old Sep 29, 2010 | 08:12 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: roller rockers
Are you fitting self aligning or non self aligning roller rockers?
If you use the self aligning type on your '89 engine you don't need guide plates.
Conversely if you are fitting NSA rockers you need the guide plates and new hardened pushrod to suit
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
