Please Help!!!!
Old Oct 2, 2010 | 06:50 PM
pestrada38's Avatar
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
Please Help!!!!
I fixed my oxygen sensor, drive belt, idler pulley, spark plugs and new wires, new cat. convert. Oil change. I also adjusted the timing and still have the same problem. When i turn the ac or when my car gets hot its start to knock . Can it be a vacuum line? I have checked everything and still no luck. Im going to replace the other cat. converter next week. Hope that helps. If it had a vacuum leak does the check engine light turn on? Please Help... Thanks
Old Oct 2, 2010 | 09:14 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Please Help!!!!
Knock sensor. SES light? Codes?
Old Oct 2, 2010 | 10:25 PM
pestrada38's Avatar
Re: Please Help!!!!
no ses light since i replace the oxygen sensor. where is the knock sensor located? does it even have one?
