Which heads will be good with my build? Looking at AFR, fastburn, bow tie etc
Old Oct 13, 2010 | 10:56 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
I am considering the vortec fastburn 210's. the GM bow tie, E-tec 200's and the AFR 190's.
I am building a forged L98, It will be fully forged internals and am looking into a dual pattern cam because I want to spray it alittle also.
For a mild 350 which heads would you choose?
Old Oct 14, 2010 | 09:37 AM
Axle/Gears: G92
Re: Which heads will be good with my build? Looking at AFR, fastburn, bow tie etc
My mine concern is the iron heads are gonna lift under the shot.
Old Oct 14, 2010 | 10:10 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
If you can afford them, I would go with either the AFR 180cc or 195cc heads. What else is being done to the motor?
Old Oct 14, 2010 | 10:28 AM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
The Vortec manifold stock flows about 220-230cfms. That about the same as stock. Not worth it. If you do a major port job to it, it will only get up to 260-270. Dyno Don has this combo with E-Tech 200 and made 370rwhp@5500-409rwtq. Major port work was done but it wasn't worth it. Look at my sig below. This hp is with medium port work and 30 less hours.
Your best bet is the AFR's 195. Make sure your manifold flows 290-310cfms for best results.
Old Oct 14, 2010 | 01:11 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Dittos to what Vincent said.
Old Oct 14, 2010 | 03:40 PM
Axle/Gears: G92
They don't make vortec 195's only 190's..
I will eventually put a D1sc on it, the block will be fully forged, rods, pistons, crank, I'm just worried the iron heads would lift.
CRFred
Feb 7, 2016 11:39 PM
Reddeath210
Oct 6, 2015 08:20 AM
355tpipickup
Aug 13, 2015 07:35 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
