Vortec TPI Cam Help
Car: 92 Camaro RS
Engine: Vortec TPI 412
Axle/Gears: BorgWarner 327 Limited Slip
Vortec TPI Cam Help
I need a new cam for my 92 camaro Z28 i did a vortec long block on it and i need to know the max safe lift on i can go with the vortec heads being stock?and what would be a good cam to put in it. i have emissions to keep in mind . Thanks
Car: 1991 Camaro z28
Engine: TPI 350
Transmission: Auto 700-4r
Axle/Gears: 3,23
Re: Vortec TPI Cam Help
I read on here somewere stock vortec heads limit is .470 i could be wrong dont know for sure.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Read this.
https://www.thirdgen.org/forums/tech...mods-info.html
It came in a couple minutes using the search.Not trying to be an a$$,but most all questions you can think of have been covered.Especially when it comes to vortec heads.Its commonly thought of as .480 lift but some have gone further without issue and others even less.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
