Question on TPI rebuild: Can I do it with the engine still in the car?
Old Oct 28, 2010 | 09:11 AM
Looksthakill's Avatar
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Hello!
I am thinking about rebuilding the engine in my '86 Z28 5.0 TPI. Question: Does the engine have to be removed to accomplish this? I want to "take my time" and do it myself, a bit of a "fun" winter project. hehehe. I would like to upgrade the cam while I am at it, and maybe upgrade the pistons as well. Also going to do headers and full dual exhaust. However, not sure if I have to remove the block or not. Please share your thoughts. THANKS!
Note: At this point, I am not interested in swapping the block for a 5.7.
Old Oct 28, 2010 | 09:26 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Question on TPI rebuild: Can I do it with the engine still in the car?
A proper job can't be done with the engine in the car.
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
If you plan on boring the block and/or getting oversized pistions, they you obviously have to remove the block.
The vast majority of time if there are many miles on the engine, the cylinders will be out-of-round and will need to be bored.
Even if you are just 'freshing' up the engine with new rings and bearings and new cam as you said, it will be much easier to do all of that on an engine stand rather than leaning over/crawling under the car to do it.
Old Oct 28, 2010 | 06:42 PM
Engine: 5.0 LG4
Thanks guys. I appreciate it!
Old Oct 28, 2010 | 07:20 PM
Guest
Guest
Posts: n/a
I agree.
It can all be done in the car, but only a stupid Pontiac dealership would ever actually do that. The rest of us have more than 1 brain cell and just pull the motor.
84z96L31vortec
Aug 20, 2017 12:16 AM
Wade787b
Sep 29, 2015 01:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
