tpi on a 70s small block
Old Jan 4, 2011 | 11:08 AM
87z28roc's Avatar
Car: 87 Iroc
Engine: 383 cid
Transmission: t-5
I working with a c4 vette (tpi) the guy came across a built small block from a 70s chevy but we would like to know if the tpi manifold would fit with out having to modify the manifold or the head, btw the valve covers are perimeter bolt. Does any one know if this would be a problem
Old Jan 4, 2011 | 12:16 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: tpi on a 70s small block
as far as i know it should work. i have a 60s small block thats now fuel injection. stealth ram. and my heads are 882s with perimiter bolt. but im no expert on "what year had what".
Old Jan 4, 2011 | 12:17 PM
Engine: 383 hsr
the main consern would be heads. considering thats what the tpi will bolt to.
Old Jan 4, 2011 | 12:46 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
the only difference with small blocks heads other than vortec's.. they're their own monster.. is the angles on the center 4 bolts for the manifold... which all you need is a die grinder and you'll be fine to just widen them out on the manifold
Old Jan 4, 2011 | 12:48 PM
68Strat's Avatar
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
What year is the C4? if its an 86 with perimeter bolt valve covers, then the TPI setup should have the old style compatible intake manifold with the four straight center bolt holes if I am correct. the 85 and 86 TPI setups would be the only option for stock pre 86 heads without modification.
Old Jan 4, 2011 | 12:50 PM
68Strat's Avatar
Engine: 360
Yeah that is no biggie, didn't see this post as I was writing mine. I converted a post 87 TBI motor to carb and it was a piece of cake to angle the holes.
Old Jan 4, 2011 | 05:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by 68Strat
if its an 86 then the TPI setup should have the old style compatible intake manifold with the four straight center bolt holes if I am correct. the 85 and 86 TPI setups would be the only option for stock pre 86 heads without modification.
All C4 TPI intakes have old style reg intake bolt angle.
When GM fitted the alum centerbolt heads to Vettes in '87 they didn't change the bolt angle like they did on the cast iron F-Body heads '87+
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
