350 with my 305 TPI setup? help?
Old Jan 4, 2011 | 05:01 PM
Blue1990camaro's Avatar
ok so i have a 1985 Z28 camaro, 305 TPI, i can get a hold of a early 70s 350 010 block complete with heads, now, im makin bout 215hp, since its just stock, i wana bump that up to around 350hp, if i use this 350 block what all shuld i do?
if i just keep the botom end stock n get a nice comp cam n headers on it, what heads shuld i use? the stock camaro 305s heads or the heads on the 350? think they r 202 heads, how much hp think i cn get outa it with just headers n cam?
just looking for sugestions before i start,
Old Jan 4, 2011 | 05:06 PM
b1lk1's Avatar
Car: 1983 Z28
Axle/Gears: stock 7.5"
Re: 350 with my 305 TPI setup? help?
Check the head and block casting numbers BEFORE you buy them. 75%+ out there are junk castings. I just had to turn down a "hi po" 327 because after running the casting numbers I learned it was the "lowest po" 327 built. Casting numbers don't lie.
As for your build, you'd be far better off locating a later model roller motor and building that.
Old Jan 4, 2011 | 05:44 PM
not tryna really make to much of a project outa this camar since its all original and rust free, if i culd get 325hp outa the 305 by all means id love to, any ideas on it since its original motor to the car?
Old Jan 4, 2011 | 05:45 PM
cam? heads? headers? injectors? throttle body? uhh lol its rated at either 215 or 275 i dont remember, but is there anway to get around 300-325hp from it?
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
drathaar907
Aug 6, 2015 04:20 PM
