Sparkplug Wires 85 TPI
Old Jan 8, 2011 | 05:43 PM
darrlee's Avatar
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
I have an 85 with the 305 TPI. When I got it the plug wires were zip tied in place and one was burned through from the exhaust mainifold. I put new wires on it and ran them over the the top. I did not see any holders anywhere to keep the wire from hangin too close to the exhaust manifolds, and now they are runnign hot again. While I was under the car I noticed some holders at the base of the block as to bring the wires in from the bottom. Does anyone have a pic or diagram of the stock loction for running the wires. Or has anyone come up with an aftermarket solution to protect the wires from the manifolds and keep them from over heating. When they get hot the car runs like crap.
Any help out there, I'm open to any and all suggestions or solutions. Thanks!!
Old Jan 8, 2011 | 07:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Sparkplug Wires 85 TPI
http://www.summitracing.com/parts/SUM-350119/
Cheaper on eBay
http://cgi.ebay.com/ebaymotors/BLACK...Q5fAccessories
Old Jan 9, 2011 | 02:02 PM
darrlee's Avatar
Car: 85 IROC
Thanks for the info on the sleeves. Looks like something to add to my wires, but I would still like to find out the original location/route of the iwres from the factory. Until I do a rebuild of the top half and add headers (next winter project), I need to keep them from over heating this coming summer.
Old Feb 7, 2011 | 10:37 PM
darrlee's Avatar
Car: 85 IROC
Still looking for any pics or diagrams of where the OE plug wires were run from GM originally on the 85 IROCs
Old Feb 26, 2011 | 11:04 PM
darrlee's Avatar
Car: 85 IROC
Old Feb 27, 2011 | 12:07 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I don't have a pick but the wires on the left side should go on a clip at the ex.man.and the wires on the right go down under the ex. man. and up behind the engine block up to the dist.Their should be a wire holder on the rear of the block
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
Sanjay
Aug 12, 2015 03:41 PM
