what type of fuel injectors do i have? pics up
Old Jan 8, 2011 | 06:42 PM
jaygt's Avatar
Car: 80,81,85, trans am
Engine: 4.9,301turbo,350
Transmission: all auto
Axle/Gears: 308,342,308
are these stock? from what you guys say stock injectors are bad so curious what they are. i have 185 000 kilometers on my 91 trans am.
Old Jan 8, 2011 | 07:06 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: what type of fuel injecters do i have? pics up
they are not stock, the stock would be rochester multecs. They are 19 lb injectors made by SMP.. they are sold by summit and most auto parts stores. They work fine but do rust outside easy..
Old Jan 8, 2011 | 08:21 PM
jaygt's Avatar
$1100 fuel injectors that would be cool. i went to the summit websight and they dont look like the picture of smp on there. can anyone confirm they are smp?
Old Jan 8, 2011 | 08:45 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
irocuroc is right on the money!!!! They are not stock. For future reference, I posted a picture of ALL the stock F.I. that Chevy installed in our 3rd Gens.
Old Jan 8, 2011 | 09:10 PM
jaygt's Avatar
can you put a link here. having trouble finding your post or pics of fi. i have another 91 trans am that wont run after it gets warm and smells rich.
Old Jan 8, 2011 | 09:16 PM
If you look closely to the design (pictures below), it is very similar to the one you posted. So due to the age of your injector and compairing to this one, it is close. Keep in mind that designs change all the time as the years go by. So your injector could be the one here ( http://www.summitracing.com/parts/SMP-TJ100/?rtype=10 ) on Summit.
Attached Thumbnails what type of fuel injectors do i have? pics up-smp-tj100_uh-injector.jpg
Old Jan 8, 2011 | 09:19 PM
Link to what?
Old Jan 8, 2011 | 09:21 PM
Re: what type of fuel injectors do i have? pics up
I tried running and searching for that stamped number and I had no success. This will be a tough one to find out what it is.
Old Jan 8, 2011 | 09:32 PM
jaygt's Avatar
honestly thanks for your help. i just bought the car and got it home last night.
my other 91 ta wont run after it warms up and i was just about to do the fuel pump. i will take a pic of the injectors in it tomorrow. if they are stock motec i will chang them first. you have a pic of a stock 5.0 motec?
Old Jan 8, 2011 | 10:35 PM
go up to my post (#4) and click on the picture. There is a list of the "out of the factory" injectors as well as theyre rated flow rates. Use the picture as a guide. If any of the 305 match up, then there you go. But if the numbers dont match, then you'll know that the PO replaced them in the past. most of the time, if you get the stamped numbers off of an item, AutoZone can cross reference them. But dont get your hopes up. AZ has figured out a lot of parts for me and they also have hit dead ends too. But its a start for your product search. Summit Racing too can help. Just call and select customer service. Tell them the part number or stamped number on item and they will pull up a data base full of part numbers (OEM and aftermarket).
Old Jan 8, 2011 | 11:04 PM
southbay08's Avatar
That actually looks like a Lucas part number
Old Jan 8, 2011 | 11:24 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello jaygt!!
Those are not the original fuel injectors, check out www.racetronix.biz item code is 01D041X, the x is in place of the 6, they have them listed as Brands: "Racetronix", Manufactures: "Standard Motor Products" otherwise known as SMP!!
Thanks to irocuroc, he was right on the money!!
The original "Multecs" probably crapped out a long time ago!!
Old Jan 9, 2011 | 12:05 AM
southbay08's Avatar
The item number is an SMP part, but it is a Lucas number, an O1D....is usually Lucas. From approx 2005-2009 SMP was licensed to distribute Lucas parts. Bottom line is that irocuroc is absolutely correct they are NOT Multecs.
Old Jan 9, 2011 | 12:13 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
See this link, it is a Racetronix/Lucas
http://www.racetronix.biz/items.asp?...atus=0&Tp=&Bc=
Old Jan 9, 2011 | 01:55 AM
jaygt's Avatar
you guys are great thats exactly it. are they ok? good injector?
well i guess i just need one set for my other 91 trans am. southbay seams to be a good company to get them from. whats the deal with the ones that say "get more hp" for less money than the bosch 111.
the green one smells rich and dies out when it warms up. about 10 minutes. then wont start. thought it was the fuel pump but now it sounds like it might be the injectors. im going to look at them tomorrow and see if they are stock.
Old Jan 9, 2011 | 05:38 PM
jaygt's Avatar
just took this picture of the injectors in my 91 green trans am. any idea what type they are?
Old Jan 9, 2011 | 06:07 PM
Those are GM Multecs. But also, they can be MSD Compitition Fuel Injectors. The GM Multecs are identical in design compared to your injectors. But then Agian, the MSD also has the same design, but the colors match yours. if your really curious, then you'll have to pull of the plenum and lift the fuel rail and get on out to look for any serial or models numbers that may be stamped on the body. Thats how you will know exactly what it is, by noting the numbers that are stamped on it. Here is how I made my determination of your fuel injectors. As for the Bosch III, I got a set and I LOVE THEM!!!!!! No more hesitation when I need to jump off of the red light! Instant power!!!!
42.jpg?t=1294618027
47.jpg?t=1294618027
Old Jan 9, 2011 | 06:27 PM
jaygt's Avatar
wow thanks again for the help. so they should be black? in 1991 they came from the factory with these f.i. but black?
i think the guy i bought the car off said he replaced the f.i. trying to fix an issue. well about a year later it slowly ran bad and would stall. to the point now after 10 minutes when it warms up it will not run. i will take them out and replace them anyways. i cant afford a mechanic to troubleshoot. if it doesnt take care of the problem then i guess i will change the fuel pump.
Old Jan 9, 2011 | 06:57 PM
Well like I said earlier. As time goes by, items do change in appearance, demensions, style, and color. Companies try to catch your attention with looks and information that isnt really relavant. For example, lets say a brand name fuel pump claims that their fuel pump will give you gains anywhere form 10-20 hp. Although this may be true, BUT the flow rate of the fuel injectors and the Fuel Pressure Regulator will still operate at its rated potential in which you'll never feel or get that so called "10-20 hp." Back to topic at hand, they could be black, grey, or natural metal color. So you'll never know unless there is a part number stamped. But do remember that some parts dont have anything on them. So if you run into a part that doesnt have a number, then it all comes down to the guessing game. Another thing to remember is that our 3rd Gens are OLD. Hell, I think about my 86 IROC and then I think "Damb, my IROC is 25 years old." My car is only 5 years younger than me and Im starting to feel the affects of middle age.7 more months and Ill be 30. That suxs.
Old Sep 2, 2011 | 11:13 PM
justins91z28's Avatar
Car: 91 z28
Engine: 5.0l 305 tpi bone stock
Transmission: auto
Axle/Gears: stock
i just changed the injecters in my 91 z28 5.0L they came out of a caddy and i lost most of the retaining locks i thought it might work without it but i keep getting leaks its my first time messing with the tpi dos any one know it the locks could be causing the leaks or maybe the injecters are not big enough
Old Sep 2, 2011 | 11:53 PM
OOOhhhh. I HIGHLY SUGGEST THAT YOU DO NOT DRIVE THE CAR!!!!! Sorry for yelling but you seriously need to lose your keys until you fix that leak. Unless you want you car to catch on fire, thren go ahead and drive it. You need those locks in order to keep the injectors in place. YOu have to remember that the fuel pressure is around 50 lbs. so yes, they will move down. You can find those locks online. Ive seen them before. Did you put a little bit of oil before you slipped the injectors into the rails and manifold? when you do find the locks, oil the o-rings on both ends. Install then into the rail first. then lock them. then put a little bit of oil into the seat on the manifold. Then put on the whole rail into place and gently push down to be seated in the manifold.
Old Sep 3, 2011 | 03:39 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Originally Posted by Chevy86 IROC-Z
Link to what?
I would like the link to the rest of that TPI swappers guide if you have it..Thanks.Tom
Old Sep 3, 2011 | 03:45 PM
If your interested in the guide, I can sell it to you for $10, then I can upload it and provide u a link so that u can download it. Let me know if your still interested.
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
