Any sugestions on 305 cam?
Car: Trans Am GTA
Ok guys so I was looking at http://www.summitracing.com/parts/CR...e%7c5.0L%2f305 and was wondering if I could use this cam on my unmodified stock 305 motor? (I dont know anything about cams or cam swaps
)If not what would I have to do to the 305 to make it work? (Engine swap is out of the question)Anyway here are the specs for the cam: crane cam .454 lift 272 duration
Its a 91' 305 TPI bone stock with a roller cam (edit)
)If not what would I have to do to the 305 to make it work? (Engine swap is out of the question)Anyway here are the specs for the cam: crane cam .454 lift 272 durationIts a 91' 305 TPI bone stock with a roller cam (edit)
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Re: Any sugestions on 305 cam?
The minimum information that we will need to help you is what year engine and what kind of intake system you have.
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
agreed with above. I replaced my cam. Never replaced the lifters. I had a roller cam.
Roller or non-roller is the 1st question.
I installed the crane 2032 cam # 104224
I also bought new springs. I kept my stock lifters.
