ZZ4 ?
Old Jan 27, 2011 | 08:35 PM
  #51
InjectorsPlus's Avatar
Former Sponsor
Re: ZZ4 ?
BOTA, PM me. I have a deal with a couple manufacturers, I can swing you a better deal than that.
That's $1200. I am fairly certain I can get you into a pair for about $800 from a top manufacturer. If we're just playing the price game, let me see what I can do to help you.
Shoot me a PM.
Old Jan 27, 2011 | 08:37 PM
  #52
ray jr's Avatar
Re: ZZ4 ?
Originally Posted by Bota 65
These are the heads I was thinking of, I should probably stay under a grand i'm thinkin.
http://www.summitracing.com/parts/NAL-12556463/
if your going to do the aftermarket thing and want to keep it cheap then also look at the heads vetteoz recommended ... those zz4 heads from summit are 1240.00 for the pair and the trick flows are around 1100.00 ..just a thought ..
Old Jan 28, 2011 | 01:23 PM
  #53
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: ZZ4 ?
I was under the impression that you already had the ZZ4 heads and cam.
I wouldn't buy those GM heads for $1200, they simply aren't worth it. There are much better options at that price range if you really want heads. Those are great if you can get them used but nothing special if you are paying retail. Also consider they are pre 86 bolt pattern and your intake base is 87+.
The entire intake will be a restriction, it restricts the stock 165cc heads that are on there now, let alone any decent cylinder head. You'll need to work this into your budget if you want to meet your goal.
Don't just buy things because they sound cool, you don't need aftermarket cranks and rods for what you want. Have yours turned and ARP rod bolts installed.
There are plenty of heads to meet your goal though. Your concern should be how to get the TPI to breath at the RPM it will need to spin to make the power.
Old Jan 28, 2011 | 02:56 PM
  #54
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
Re: ZZ4 ?
this is why the whole heads debate was started, its already been said
Old Jan 28, 2011 | 06:49 PM
  #55
Bota 65's Avatar
Car: 1987 Formula
Transmission: 700 R4
Axle/Gears: 3.42 L/S
Re: ZZ4 ?
My apologies I didn't notice the price was for each. Thanks for pointing that out. I am not stuck on the ZZ4 by any stretch, it was what a local guy i know tossed at me as what he thought was a good setup. He hasn't really done any TPI related engines which is why I came here. I know somebody on here has done about anything and everything that can be done to these motors and cars. I have been listening and looking at everything you guys toss in here to see what I might like.
Old Jan 28, 2011 | 07:51 PM
  #56
ray jr's Avatar
Re: ZZ4 ?
when i saw the way summit listed the zz4 heads as each and tfs as a pair i kinda thought you might of not noticed that .. good luck with your build ..
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
