tpi cam HELP
Old Feb 3, 2011 | 10:07 PM
bull600's Avatar
Car: chevelle
Engine: 350 tpi
Axle/Gears: 3.55 12 bolt
tpi cam HELP
I have a 1969 chevelle with a tpi set up from a camaro it has a holley stelth ram intake headers and 22#injectors and a 86 mass air flow computer. The engine is a late model 350 with a l79 camshaft .222 .447 and some 882 heads. I know the cam profile is all wrong but what info I have found has not helded find the proper cam to make the car run right. It does not idle well. I need a good hyd flat tappet cam. HELP!
Old Feb 3, 2011 | 11:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tpi cam HELP
If it is late model are you sure it can not take a roller cam?
Flat tappet cam will fit in roller block
Old Feb 3, 2011 | 11:22 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: tpi cam HELP
Are you running the stock mass airflow system? If so it should be able to adjust for the larger cam. Check your timing setup, and your idle adjustment. But be aware the stock computer can only handle so much.
Old Feb 4, 2011 | 08:18 AM
BadSS's Avatar
Re: tpi cam HELP
Yep,, that L79 is a little bit of a dog performance wise,, but it should idle decently with the right "tune" as 1983Chimaera suggested - as long as you have a 350 chip with those 22# injectors. You need to check that since the 86's (you computer reference) only came with 305s,, it's possible you have a "305 chip" in it. If you do,, the injector constant will be for 18# injectors and you'll run really rich at idle. The info below is assuming you have a "350" chip that matches the 22# injectors.
The HSR likes a lot more timing than the TPI - especially in the lower RPM range. To get it "right" you need to be able to burn your own chip for the timing and the fuel. When I did my HSR swap, I had to jack the base timing up to 12-degrees and add about 4psi to the "TPI" fuel pressure setting with the stock 350 chip to get the HSR to run "decent". Again, you need to burn your own chip, but it should idle and run decent with a stock 350 chip, 12-degrees base timing, around 45psi fuel pressure, with the minimal idle set at 500rpm, and the TPS set to give you 4.25v (or more if you can get it) open and 0.6 volts closed.
If the current "tune" is way off now,, you'll have to adjust the idle screw between settings,, and will more than likely need to go through the minimal idle setting procedures two or three times. I was able to get mine to idle fairly well running more overlap than your cam. So,,,, if you get the timing and minimal idle settings all working together it should idle and run "decently".
Old Feb 4, 2011 | 05:24 PM
bull600's Avatar
Car: chevelle
Engine: 350 tpi
Re: tpi cam HELP
i was concerned about the las only being 106 instead of somewhere around 112
Old Feb 5, 2011 | 05:59 AM
BadSS's Avatar
Re: tpi cam HELP
Lobe seperation angle on a L79 cam is 114-degrees,the L76 mechanical cam it kinda replaced is 106.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
