Carb to TPI
Old Feb 5, 2011 | 12:57 PM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
Carb to TPI
I'm sure this has been asked before maybe even numerous times but is there a benefit from swapping from a carb to a TPI? I understand that a fuel injected engine will last longer but for the trouble and expense is swapping worth it?
Old Feb 6, 2011 | 12:37 PM
hartsmike's Avatar
Axle/Gears: 273
Re: Carb to TPI
Nobody has any thoughts?
Old Feb 6, 2011 | 01:02 PM
InjectorsPlus's Avatar
Former Sponsor
Re: Carb to TPI
If you're interested in swapping, I have to look around but I think I have an old TPI setup at the shop. I also have a 1990 COrvette ECU which is a MAP ECU, and I believe I have the chip. The only thing missing is the harness.
The benefits to switching are easier starts, better fuel control, which results in smoother overall operation, and better reliability.
You don't have to switch all the way to a TPI. There are throttle body systems
There's a number of ways to go, depending on desires and budget. .
Old Feb 7, 2011 | 01:59 PM
hartsmike's Avatar
Axle/Gears: 273
Re: Carb to TPI
The budget wont be much but I was wondering if it is cost feasible? I mean to change over you'll have to run fuel lines to an new gas tank and fuel pump in it then all the electronics.. Wonder if the gas milage would increase enough to justify it?
Where are you located?
Old Feb 8, 2011 | 11:48 AM
Mayjor's Avatar
Car: 1989 Camaro RS
Re: Carb to TPI
Dont mean 2 thread jack here but im also thinking about converting...i have the opportunity to get a complete tip setup harness ecu and everything for about 400...im running a carbed 305 right now and want to also to a 5 speed swap...what kind of increase in gas mileage should i expect with the tpi...and will a decent 5 speed hold up with a tpi 305?
Old Feb 9, 2011 | 07:56 PM
89 ROCKINGFLAME's Avatar
Re: Carb to TPI
delete my post
Last edited by 89 ROCKINGFLAME; Feb 9, 2011 at 08:43 PM. Reason: to create a new ,separate thread
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
