Changing Fuel Pump On '90 Iroc-Z TPI
Old Feb 17, 2011 | 02:27 AM
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
After Dropping The Rear End & The Gas Tank Is Taking Out The Old Fuel Pump & Connecting The New Fuel Pump And Dropping It In Difficult? I've Never Changed A Fuel Pump Before But Im Kinda Short On Cash So I was Thinking Of Doing It Myself. I heard It Has To Go In A Certain Direction Or It Wont Work Properly And Is Connecting The Fuel Lines And Wires A Pain? I Was Planning On Getting A 255LPH Pump Because I Plan On Doing An LS1 Swap Within The Year & Dont Want To have To Change It Again, Im Looking At This Particular One On eBay, Any Advice On Anything Im Planning On Doing? Thanks
http://cgi.ebay.com/ebaymotors/Perfo...ht_1778wt_1094
Old Feb 17, 2011 | 01:50 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: Changing Fuel Pump On '90 Iroc-Z TPI
Not that difficult changing the old fuel pump, the majority of the work is in dropping the rear. Once you have the tank out it would be a good idea to clean out the tank, also don't forget to replace the fuel filter. You might consider a different pump, do a search on brands and feedback, it would a shame considering all the work involved in changing a pump it you put in a crappy pump.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
