motor wants to stall when at a stop?
Old Mar 7, 2011 | 07:55 PM
  #51
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: motor wants to stall when at a stop?
Or you can use a large zip tie or duck tape to hold it in place for a while.
Old Mar 7, 2011 | 08:10 PM
  #52
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
tried tape and it just comes off...ill try a zip tie to get me down to the yard..haha
Old Mar 7, 2011 | 08:53 PM
  #53
HighTechRedneck's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: Stock 9bolt posi
zip tie sounds like it would do the job!
Old Mar 7, 2011 | 09:05 PM
  #54
itsMikey's Avatar
Engine: 5.7 350 TPI
alright so we'll see..zip tie is in place..
Old Mar 7, 2011 | 10:52 PM
  #55
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I thought of a zip tie when I was writing my last post on finding a new connector. It would work though a new connector would be much more sano.
Old Mar 8, 2011 | 10:29 AM
  #56
itsMikey's Avatar
Engine: 5.7 350 TPI
yeah ima check the yard today if i get a chance..
Old Mar 8, 2011 | 03:19 PM
  #57
itsMikey's Avatar
Engine: 5.7 350 TPI
http://www.hawksthirdgenparts.com/co...1-1-1-1-1.aspx
lol...gonna just order these
Old Mar 8, 2011 | 11:37 PM
  #58
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Right on! Wasn't sure if they're available aftermarket, but looks like they are.
Old Mar 9, 2011 | 10:07 AM
  #59
itsMikey's Avatar
Engine: 5.7 350 TPI
gonna try the zip ties first..just cuz Hawks shippng is A LOT...
Old Mar 9, 2011 | 11:02 PM
  #60
itsMikey's Avatar
Engine: 5.7 350 TPI
so it did it again tonight and now i KNOW its not the ecm connectors
its only initiating the ses light when i hit a bump...
so now what? looks like im ridin the bike to school 2marro..lol
Old Mar 9, 2011 | 11:17 PM
  #61
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
You never did read codes did you. Knowing what code it throws would help determine where the short circuit is. Read codes, wiggle test the affected sensor circuit with the car running. Since the car is stalling as part of the failure, I would look at the circuit supplying power to the fuel pump, injector circuits, ignition circuits, etc. The problem is only perplexing because you haven't found it yet. also, don't assume the ECM connectors are okay. I almost said it the other day but didn't want to jinx you. The connector(s) coming loose like they did can detension the terminals, causing poor contact. Hold the ECM in your hand with the car running and wiggle test the individual circuits at the connectors. Whuile wiggling the circuits, look for any change in idle, or for the SES light to come on.
Old Mar 10, 2011 | 09:59 AM
  #62
itsMikey's Avatar
Engine: 5.7 350 TPI
will try to wiggle test the ecm later...
maybe its a bad ground from the negative battery terminal? it felt pretty dirty down there (on the block)
the only code it was throwing was a 12...i checked it again last night
Old Mar 10, 2011 | 11:07 AM
  #63
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Yeah. The ECM isnt storing the code. Makes me think its an issue with the ECM itself , or a power or ground to the ECM. Go ahead with the wiggle test. And carefully check the ECM power and ground circuits. Try gently shaking the ECM with the engine running, and even rapping it with your knuckles. It may have an internal fault.
Old Mar 10, 2011 | 11:11 AM
  #64
Engine: 5.7L TPI
Okay, definitely just start following wires, check ALL your grounds. Make sure connections are good. There aren't that many wires on these cars you should be able to find it. Sounds like an electrical thing to me.
Old Mar 10, 2011 | 01:21 PM
  #65
itsMikey's Avatar
Engine: 5.7 350 TPI
maybe the magnet killed the ecm? lol...
will try the wiggle test and check all around for loose grounds and wires.
if all else fails, thinking it could be a bad ecm?
Old Mar 10, 2011 | 01:57 PM
  #66
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The ses light with no stored codes makes me suspect the ECM. I'm curious to hear what you find by rapping on the module with the engine running. Bet you recreate the symptoms. I've had some success repairing ECMs when the problem is just a broken solder joint. I really don't think the magnet would have hurt it. But then again it couldn't help anything.
Old Mar 12, 2011 | 12:11 PM
  #67
itsMikey's Avatar
Engine: 5.7 350 TPI
havent had a chance to wiggle the ecm..
but i was just thinking, could it be a bad alternator? cuz its not initiated by a bump anymore...it just randomly happens.
Old Mar 13, 2011 | 12:41 AM
  #68
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Does system voltage drop when the problem is occuring? If so than it could certainly be the alternator.
Old Mar 13, 2011 | 03:43 AM
  #69
itsMikey's Avatar
Engine: 5.7 350 TPI
dammit, i didnt even think to check that! ill check it 2marro..OH! the wiggle test did nothing to the ECM...
so im thinking alternator or a fat vacuum leak?
Old Mar 13, 2011 | 12:07 PM
  #70
itsMikey's Avatar
Engine: 5.7 350 TPI
its gotta be something electrical cuz when it starts doing this, when i turn the ignition on, the fan comes on.
also, when i start it, it idles really high.
Old Mar 13, 2011 | 01:58 PM
  #71
itsMikey's Avatar
Engine: 5.7 350 TPI
okay.went out to it right now and its running fine BUT
i look under the car and under the hood...car is leaking coolant like a ****...seems to be coming from the water pump..maybe its just the hose but a bad water pump wont cause all this will it?
Old Mar 13, 2011 | 04:36 PM
  #72
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
If the block is very low on coolant, it could cause the CTS to read low which will affect idle, but not cause the fan to run on. It's not likely that the coolant leak is related to the drivability issue. A few things can cause the fan to run on and the idle to go high. The ECM being in diagnostic road test mode could cause this. Again, go over your wirning to see if yo can recreate the problem by wiggling any part of the harness. After you fix the coolant leak.
Old Mar 13, 2011 | 11:26 PM
  #73
itsMikey's Avatar
Engine: 5.7 350 TPI
alright..ill try and follow the harness out 2marro. i went to the zone and got a new hose, there was a HUGE hole on the lower hose -_-
Old Mar 14, 2011 | 11:29 PM
  #74
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
An open or short in the coolant temp sensor circuit will cause the fan to run on as the ECM goes into default without CTS input. Try filling the engine with coolant and see if the problem is gone.
Old Mar 14, 2011 | 11:38 PM
  #75
itsMikey's Avatar
Engine: 5.7 350 TPI
alright...
fixed the hose, filled with coolant
ALSO replaced the serpentine belt because the old one was old af -_- was cracked and stuff...
still doing it BUT now its throwing a code 42...YAYYYY!!!!!!! haha..at least its giving me something now....
so, i was looking and you just happen to reply to this one as well.
https://www.thirdgen.org/forums/tpi/...rank-wont.html
OR
the est wire?
https://www.thirdgen.org/forums/tech...de-42-est.html
fan isnt turning on and its not stalling anymore...just really hesitant and a huge lack of power
so, maybe its the dizzy or the pickup coil?
the ignition module is brand new, the MSD cap and rotor are new as well as the MSD wires....
Old Mar 14, 2011 | 11:45 PM
  #76
itsMikey's Avatar
Engine: 5.7 350 TPI
just as a reference,
42. Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit
Old Mar 15, 2011 | 11:16 AM
  #77
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Code 42 will set when the ignition module doesnt recieve pulses from the ECM for 200ms when EST is activated. This condition will cause the engine to stall and restart. On restart, the engine will run on the ICM's own timing map. The code will also set if the system is run in bypass mode(tan black wire disconnected), as when setting timing. Try the timing adjustment procedure after youve carefully inspected all wiring around the distributor. Pull the cap and check the connections inside as well.
Old Mar 15, 2011 | 01:25 PM
  #78
itsMikey's Avatar
Engine: 5.7 350 TPI
will check it all out when i get home later...
i just dont see it being the igniton module because i replaced it not even 6 monthes ago...
Old Mar 16, 2011 | 07:50 AM
  #79
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The intermittent nature of the problem doesn't sound like an igntion module but more like a wiring fault. Carefuuly check the tan/black wire and the white wire between the ECM and distributor.
Old Mar 16, 2011 | 10:07 AM
  #80
itsMikey's Avatar
Engine: 5.7 350 TPI
will check it later...does the wire go straight from the distributor to the ECM?
still havent checked all the grounds >.>
Old Mar 16, 2011 | 10:09 AM
  #81
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Yes. The wires go straight to the ECM.
Old Mar 16, 2011 | 11:12 AM
  #82
itsMikey's Avatar
Engine: 5.7 350 TPI
alright..
ima clean all the grounds and check that wire out...
if its still doing it, im just gonna buy a new ECM i think.
Old Mar 16, 2011 | 06:28 PM
  #83
itsMikey's Avatar
Engine: 5.7 350 TPI
everything seems good with the wires....
maybe this will clue us in? is my ses light supposed to do this at ignition? and now it wont turn over -_-
http://www.youtube.com/watch?v=Dyoodmsbozk
Old Mar 16, 2011 | 11:26 PM
  #84
itsMikey's Avatar
Engine: 5.7 350 TPI
thinkin about just taking it to a shop >.<
Old Mar 16, 2011 | 11:50 PM
  #85
bungo78's Avatar
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
Bad news Mikey! I feel our pain! I had a similar situation. Only after all your symptoms, It wouldn't even kick over anymore. I too finally waved the white flag and took it to my guys money boutique(shop)
Old Mar 16, 2011 | 11:58 PM
  #86
Gibson's Avatar
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
you could just take the route im going to take with mine...carb it.
Old Mar 17, 2011 | 09:17 AM
  #87
itsMikey's Avatar
Engine: 5.7 350 TPI
dam bro..that sucks..haha
debating whether i should try a new ECM and then if that doesent work..THEN take it to a shop
Never lol
waiting for the doc to chime back in
Old Mar 17, 2011 | 02:18 PM
  #88
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
A shop may be the way to go. However, finding a technician who knows these cars could be tough. College Educated techs are only versed in the basics on older vehicles and focused mostly on more recent technology.
There is so much to know on newer cars. Most techs Ive worked with don't even bother understanding the technology but rather just read codes and replace parts. When something tough comes up they scratch their heads just like you and get on IATN or Identifix and let people like me tell them what to do.
Is your engine not cranking? Or not starting? Not cranking has nothing to do with the distributor and most likely nothing to do with the ECM. Your 89 may have Passkey VATS, if no crank, I would probably look there, after verifying no start signal to the solenoid. Do you have a good service manual? Follow the "No Crank" diagnostic flow chart.
If the engine cranks but doesn't start, you need to determine what's missing. Does the engine have compression, spark, fuel pressure, injector pulse? If it cranks and doesn't start, it's missing one of these.
Looking at your video, I saw normal check engine light function.
Old Mar 17, 2011 | 03:36 PM
  #89
itsMikey's Avatar
Engine: 5.7 350 TPI
okay so its supposed to blink when i turn the ignition on?
and i have a shop that does a lot of F-Body stuff..taken my car to them for numerous things.
its cranking but wont start...
Old Mar 17, 2011 | 04:04 PM
  #90
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I missed that. Im trying to remember when Ive seen that before. It may very well be your ECM. Sounds like you've already decided to take it to the shop. Otherwise, I would have had you look at spark, fuel pressure and injector pulse. You may have lost your ECM.
Old Mar 17, 2011 | 04:38 PM
  #91
itsMikey's Avatar
Engine: 5.7 350 TPI
not set on taking it too the shop..there pretty pricey >.>
if it was the ECM, would it start the car and run okay at times then take a dump later?
like, presenting itself as an intermittent problem?
i just took the car out for a drive and it felt "ok" THEN, i parked it back at the house, went to start it again and it wouldnt turn over again
it was doing the fan thing earlier too..
Old Mar 17, 2011 | 05:04 PM
  #92
itsMikey's Avatar
Engine: 5.7 350 TPI
just ordered a new ecm from TPIparts.com
but yeah
Old Mar 17, 2011 | 05:07 PM
  #93
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
A defective ECM can fail intermittently like anything else. Check the ECM fuse. Im trying to remember what the single flash of the SES light means. It may be no power to ECM. Try to PM Rbob, you can find him over on the DYI Prom forum. Ask him about the single flash.
Old Mar 17, 2011 | 05:44 PM
  #94
bungo78's Avatar
It's illegal to carb vehicles after '87 out here. So it would do him no good
Old Mar 17, 2011 | 05:47 PM
  #95
bungo78's Avatar
Good luck Mike! Hope it gets resolved soon. My problem was ECM related as well
Old Mar 17, 2011 | 05:58 PM
  #96
itsMikey's Avatar
Engine: 5.7 350 TPI
oh fo sho..hope mine is too..haha.
ECM fuse is brand new!
Old Mar 18, 2011 | 01:43 PM
  #97
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
PLEASE HELP ME!!! i have a 91 z28 with 5.0 automatic...heres what she does #1 speedo doesnt work and doesnt throw any codes when plugged in...i will be replacing the vss (old one was leakin fluid out the tail shaft) other and only problem with car is that when its in drive or reverse gears then after about 15-20 mins of drivetime she stalls when stopped...again no codes showin up and she fires right back up PLEASE HELP I AM FREAKIN STUMPED
Old Mar 18, 2011 | 02:09 PM
  #98
itsMikey's Avatar
Engine: 5.7 350 TPI
post a new thread...
Old Mar 22, 2011 | 04:01 PM
  #99
itsMikey's Avatar
Engine: 5.7 350 TPI
the new ECM should be here 2marro
Old Mar 23, 2011 | 04:36 PM
  #100
itsMikey's Avatar
Engine: 5.7 350 TPI
got the ecm, got it all plugged up AAAAAAAAAAAAAAAAAAAAAAAANNNNNNNNNNDDDDDD
nothing -__-
taking it to the shop when i get back from Arizona (picking up my 66 impala )
