Pulled code 42 - EST
Old Aug 10, 2010 | 01:38 PM
marcopasco39's Avatar
Car: '84 Trans Am
Engine: L69 stock
Transmission: T-5 B-W
I just replaced my ignition coil, cap, plugs, wires, pickup coil and ignition module in my 84 T/A w/ L69. I timed it very well and it ran great for about 2 months. Then one morning it had a hard time starting and the check engine light came on for 42-EST. Now it runs but it idles at about 550-600, the tach flickers sometimes, and there's a severe lack of power w/ hesitation. What the F$@# is going on? Any suggestions are much appreciated. Thanks
Old Aug 10, 2010 | 01:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Pulled code 42 - EST
sounds like the EST wire that you unplugged to set the timing came unplugged again.
Old Aug 10, 2010 | 02:14 PM
Car: '84 Trans Am
Engine: L69 stock
That would mean it would be running in bypass mode, using the ignition module for timing instead of the ETC/ECU right? I'll check that
Old Aug 11, 2010 | 06:48 AM
Car: '84 Trans Am
Engine: L69 stock
Yeah, that wire is secure and insulation seems good.
Old Aug 11, 2010 | 09:59 AM
Car: 1992 RS
Engine: Carbed 350
Only other thing I can think of is...
driver side firewall, where the fuel pump and electric fan relay are at, there is another connector there that plugs into the EST module - make sure that connection is good and secure
and make sure the wire connector to the dist is good and secure
Then disconnect the battery for 5 minutes to reset the EC and codes, and see what happens.
Old Aug 11, 2010 | 10:01 AM
Car: 1992 RS
Engine: Carbed 350
Originally Posted by camaronewbie
driver side firewall, where the fuel pump and electric fan relay are at, there is another connector there that plugs into the EST module - make sure that connection is good and secure.
Sorry - just noticed you have a different year/motor than I thought - this EST module might be elsewhere - that's just where it was at on my 1992 TBI car.
Old Aug 11, 2010 | 10:46 AM
Car: '84 Trans Am
Engine: L69 stock
Yep the L69 has the EST module in that spot, I'll check it out. Thanks
Old Aug 11, 2010 | 03:03 PM
Car: '84 Trans Am
Engine: L69 stock
I was told that my problem may be that the ignition module at the base of the distributor may be loose because the connector broke (which they usually do) and it wiggled itself out of a good connection. Any ideas?
chazman
Aug 28, 2018 03:25 PM
1992Vortec
Aug 31, 2015 08:05 PM
86IROC112
Aug 31, 2015 07:00 AM
chazman
Aug 22, 2015 02:01 PM
