17113765 injector?
Car: 91 Z28 Camaro Convert
Engine: 305,Edel,Comp,Hooker
17113765 injector?
Using a multitec injector which is stamped 17113765 in my 91 305 tpi Camaro. Have seen this advertised for use in the 4.9 Cadillac and the 305 and 350 GM engines with flow rates varying between 19 and 22 lbs. The stamped number is referenced as a component number not a manufacturing number. Does anyone know what the original use of this injector was and it's actual poundage rating? I know by test it is 16 ohms and voltage falls in the application range for the 305. Been messing up small blocks since 1959. Thought my old '65 327/375 I sold a few years back was the last. Then there was this '91 Z28 Convertible sitting by the road....Hence the handle.
Re: 17113765 injector?
Multec injector ebossed 17113765 crosses to FJ10023, max flow 2.44gm/sec, @300KPA (43.5 PSI), 19lb/hr, high impedance, application 92-89 Camaro/Firebird 305 ci.
thejimsterz28
Sep 15, 2015 04:37 PM
