Oil Pressure Switch
Old Mar 12, 2011 | 11:16 AM
jwoodworth90's Avatar
Oil Pressure Switch
Does anyone have the pinout for a 85 5.0 tpi ECM. The wire going to my oil pressure switch is cut and I need to hook it back up.
Old Mar 12, 2011 | 02:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Oil Pressure Switch
Oil pressure switch does NOT go to the ECM. It runs the fuel pump. Above oil filter.
Oil pressure sender goes to guage only, dark green wire. Sender on top of intake next to distributor.
Nothing oil pressure related runs to the ECM.
Wiring diags for almost everything: http://www.austinthirdgen.org/index.php?pid=19
Old Mar 12, 2011 | 04:08 PM
This is the wire i am talking about, so this would be the Oil pressure sender that goes to guage only correct?
Old Mar 12, 2011 | 07:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Correct
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
