Fan Temp Switch
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fan Temp Switch
use a 1/2" to 3/8" NPT reducer to fit the smaller later model switches
http://www.summitracing.com/parts/EAR-991204ERL/
or a aftermarket switch with lower fan operating temps
http://www.racerpartswholesale.com/p...n_Accessories2
Re: Fan Temp Switch
if you can't find correct OEM switch
Re: Fan Temp Switch
Earlier heads use the "big hole" (1/2" NPT thread). Later heads use the "small hole" (3/8" NPT thread).
You know the driver's side sender runs the temp gague on the dash, right? The very similar looking sender in the passenger side head runs (one of) the fan relays.
Re: Fan Temp Switch
There is just a plug on the passenger side and i thought the drivers side one on the head turned the fan on.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fan Temp Switch
Driver side head between #1 & #3 spark plugs is just the temp sender for the coolant gauge.
Pass side head between #6 and #8 spark plugs is the fan switch.
However, since all heads are identical between pass side and driver side (just turned around), the hole sizes/thread sizes are the same for either (assuming you have the same heads on each side).
Temp sender has single dark green wire to a sender with a single male 1/4inch spade terminal.
Fan switch has a single wire to the switch that has a mushroom looking connector on it.
Fan switch: http://shop.advanceautoparts.com/web..._546083209____
Temp sender for gauge: http://shop.advanceautoparts.com/web..._575798083____
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
