need major help with motor
Old Mar 20, 2011 | 08:19 PM
ponykiller1187's Avatar
Car: 1987 camaro iroc z
Axle/Gears: stock
Hey guys I have a 87 iroc with a tpi 350 I been messing with this car trying to get it running right I tried to time it by takin the number one plug out and holding my finger over the hole and had my fried slowing turn the motor with a wrench until air starting pushing my finger got it on tdc then hooked my wires on the cap in the right order so I go to start the car and nothing I do have the est wire unplugged. I try to advance it alittle and nothing. So I then reatrded it alil and it finally started up around 16degrees retard. So I try to advance it back to zero and it starts to run good but then the motor starts knocking bad. Y is it doing this any help would be excellent.
Old Mar 24, 2011 | 12:56 AM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: need major help with motor
If the distributor has been removed and reinstalled it may be off by one gear/tooth. Its easy to miss by one gear...I know from experience.
Any Check Engine Lights come on during your efforts?
hydrolic144
Sep 8, 2015 06:55 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
stalkier
Aug 21, 2015 01:54 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
