Build 305 or swap to 350?
Old Mar 23, 2011 | 11:54 PM
Nspurgas13's Avatar
Car: 1988 Trans AM
I have an 88 T/A with a 305 TPI and a 700R4. The TPI setup isn't running 100% and is very moody. Some days it runs good, others it wants to stall and has a mind of its own. In CT where i live a car has to be atleast 25 years old to be exempt from emissions testing. And if i swap to a carb'd 350 it wouldn't pass emissions and i wouldn't be able to register it. Ive saved up enough money to do one of two things, Either buy the 350 now and build it up then put it in the car in 2 years, Or i could bring it to a shop and have someone get the TPI running the way it should, What should i do?
Old Mar 24, 2011 | 02:34 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Build 305 or swap to 350?
Thats a loaded question! Do you have another car to drive while you are building the 350? I, Personally would build the motor for 350 TPI. (With more money, I would just do a LS-1 swap.)
Old Mar 24, 2011 | 07:44 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
i have a tbi 350 you could put your tpi intake on if your interested looking to get $300 for it bought it for my car but after some more digging turns out the guy that told me it was a 305 didn't know jack
Old Mar 24, 2011 | 07:54 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
i would diagnose the problem and fix it....you might have a sensor going bad or something to that effect. the money you would spend on accquireing a good 350 could be put into the 305 and can make a pretty decent powerplant that will compete with a 350. keep in mind that the TPI manifold was designed for the 305
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
