tpi fuel lines
Car: 91 Camaro RS
Engine: 305tbi out, 350tpi goin in
tpi fuel lines
hey guys i did a tpi swap and i wanted to know if someone could tell me the part number for the rubber tpi lines that connect to the fuel rail. i ordered some on ebay but when i got them they look exactly the same as the ones i was using for my tbi. plus theyre stamped with the same number that were on the rubber fuel lines for my tbi. i dont want to take a chance and use the wrong ones. does somebody know what im talkin about?
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: tpi fuel lines
GM 10055874 and 10055875. They are steel lines, not rubber and are discontinued thru GM.
Dale Earnhardt Chevrolet shouold have the 874 in stock for around $11 + S/H, found the 875 on ebay for $35 + S/H
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Re: tpi fuel lines
the metal fuel lines that attach to the rail then connect into the two rubber lines. are the rubber lines the same as on a tbi?
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
