ls6 heads on an l98
Old Mar 30, 2011 | 02:13 PM
thepatriot1991's Avatar
Car: 1989 Trans Am GTA
Transmission: Built 700r4
z
Old Mar 30, 2011 | 02:33 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: ls6 heads on an l98
No. Not possible. They are two completely different motors.
Old Mar 30, 2011 | 02:52 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I second that; apples to oranges, not even remotely close to a fit
Old Mar 30, 2011 | 05:03 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
It is correct that it can't be done it it's interesting to note that someone makes a LS style block that will accecpt SBC internals. Pisons, rods, crank ect. Supposedly it makes building an LS cheaper. It doesn't really make since to me though because if you have to buy another block you won't save anything with the cheaper internals...
Old Mar 31, 2011 | 05:05 AM
joe2844's Avatar
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
http://www.worldcastings.com/product...ron-block.html
It's actually a neat idea. Think about it, the main reason everyone loves LS style motors is bc of the power you get out of them mostly from the new design of the heads. Say you wanna swap an ls in your third gen, but you dont wanna deal with oil pan, motor mount, or front accessory fitment issues. Buy this block, add your old school sbc rotating assembly, cam, front accessories, trans, and throw a set of ls heads and intake on. Horsepower TV did a build on one of these, with all off the shelf parts and a carb'd intake manifold theymade around 500 hp. pretty cool if you ask me. now heres the downside, the block costs 4-5k i believe
Old Mar 31, 2011 | 08:06 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
actually i think the heads used on the show were LS "style heads" made to work on a SBC. i have no idea where to get them or how much they cost but i think the ones used on the show were prototypes
Old Mar 31, 2011 | 11:21 AM
built91Z28's Avatar
Yes the block is very expensive, but I also have a feeling its not being marketed towards your average person who wants LS power but doesnt want to deal with the extra things involved with the swap. Its not a solution for cheap SBC power. Its probably geared towards people who are building race motors and are going to be using an aftermarket block anyways.
My anyways.
Old Mar 31, 2011 | 12:32 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
My only question is why go through all the trouble of designing/manufacturing something really cool/new like that and then use the leaky old 2 pc. RMS? I've noticed a lot of aftermarket blocks are like that.
Old Mar 31, 2011 | 01:12 PM
built91Z28's Avatar
Not sure about that. I like 1 piece rear main blocks.
To the OP, why did you delete your post? Yeah it may not have been possible, but someone else with this same question may search for this someday and your question is gone.
lt500r55
Sep 1, 2021 01:30 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
italiano67
Aug 31, 2015 06:04 PM
86White_T/A305
Aug 17, 2015 12:16 AM
