Accel base or Big Mouth base?
Old Mar 25, 2011 | 08:42 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Right now I have a TPIS Big Mouth base (not the Edelbrock made one) with SLP runners on the car. In the garage I have a full Accel Superram setup. The question is do I swap the TPIS base for the Accel base when I put the Superram setup on? My research tells me the TPIS base is the better of the two, does anyone think or know otherwise?
Old Mar 26, 2011 | 10:50 AM
spurgeon76's Avatar
Car: 1989 IROC-Z
Re: Accel base or Big Mouth base?
Nobody has an opinion?
Old Mar 26, 2011 | 03:55 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
The older accel base is the best one out of the box. Im not to sure if you will see a big difference between the 2 in stock form
Old Mar 26, 2011 | 06:55 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
Are you gasket matching your intake parts
Old Mar 26, 2011 | 07:07 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Yes I am going to gasket match them.
WejaZ28
Oct 3, 2015 07:38 PM
85 Jimmy
Sep 30, 2015 07:56 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
webeeZ28
Sep 14, 2015 12:00 PM
e3pres
Sep 9, 2015 01:51 PM
