Another 355 build...
Old Apr 5, 2011 | 07:51 PM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
Got the '87 IROC fired up this weekend after the 305 to 350 ('89 roller block bought at Daytona Turkey Rod swap meet for $50) engine swap.
Build items worth noting:
  1. Bored 30 over w/ cast pistons and chrome moly ring set.
  2. Lunati cam - 54779LUN
  3. 081 heads w/ 1.94 intake valves. Slightly ported, intakes valve unshrouded and heads, in general, cleaned up. Stainless steel valves. Screw in rocker arm studs. Positive valve seals - intake and exhaust.
  4. 1.5 ratio stamped steel rockers (standard; not self-aligning) w/ long slots.
  5. Comp Cams 7.150 Magnum pushrods (Had to get 7.150" pushrods to maintain valve train geometry).
  6. Siamesed OE intake base.
  7. Ported OE plenum.
  8. Hooker 2055 headers and Y-pipe w/ Magna-Flow high flow cat.
  9. 27lb injectors.
  10. PROM tune (by me).
Tuning (MAF system) was fairly easy and I have about 120 miles on the engine so far. It is getting stronger by the mile and no fluid leaks, overheating or other anomalies.
Starts right up, idles good (cold and warm) and it is a blast to drive. Cam has a slight lope to it, but just right (for me).
CG
Old Apr 17, 2011 | 11:01 PM
Re: Another 355 build...
Have about 400 miles on the L98 motor now and it is fairly strong. It has more power than my '92 LT1 Corvette w/ minor bolt-ons and tune.
No official Dyno numbers, but the butt Dyno says it's fun to drive!
Now that it is somewhat broken in, the idle is a little smoother when cold and hot and throttle response is awesome.
CG
Old Apr 18, 2011 | 04:57 AM
bobbyk3lly's Avatar
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
post some enigne pics, and some car pics, of both the vette and the car with the 355
Old Apr 19, 2011 | 03:24 PM
Pab's's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI with zz4 heads
Axle/Gears: 9 bolt BW
Hey Im thinking of doing this to my Iroc could you post a video so we can hear it
Old Apr 19, 2011 | 05:07 PM
Post a video of my build w/ sound clip?
I am currently traveling, but when I get back mid next week, I will post some pics.
CG
Old Apr 19, 2011 | 07:00 PM
Pab's's Avatar
Car: 1988 IROC-Z
I apologize I meant of your car once its up and running.
Old May 10, 2011 | 02:51 PM
Now that I am back in town, I'll try and load a video this weekend.
I now have about 800 miles on the rebuilt motor and I was noticing a slight hesitation occasionally, while taking off from a dead stop. Seemed worse when fully warmed up. I disabled the EGR and all seems to be good now.
The Lunati cam I am using has enough overlap to have "built-in EGR", so to speak. The external EGR was acting like a big vacuum leak since the cam was already allowing left over exhaust in the cylinder for combustion.
Kinda figured this would be the case with the Lunati cam, but you never know until you get everything all back together and start driving / tuning.
CG
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
mike22115
Sep 28, 2015 04:49 AM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
