MAF sensor
Old Apr 7, 2011 | 08:05 PM
envy it's Avatar
MAF sensor
Anyone seen a MAF sensor for an 85 TPI ecm that will go in a conventional air cleaner? Street and performance makes them for LS engines, im wanting to put a 1000 cfm 4bbl throttle bodie on a single plane intake with multiport injection
Old Apr 8, 2011 | 09:06 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: MAF sensor
Most run a SP intake because they require more airflow so they also convert to the less restrictive SD setup
so no MAF needed.
This is most commonly used for MAF setups to retain stock MAF sensor
http://www.superiorairflow.com/carb-...-carb-hat.html
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
