96 lt1 cam dowel pin
Old Apr 9, 2011 | 07:26 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
What's up guys so If I can't trade myt1 cam for a 350 tpi cam for my 305 build ill just mske it work my question is to cut the dowel pin so I can use this cam...do I just cur it with a grinder to the correct length or how would I go about this? Thanks
Old Apr 9, 2011 | 09:02 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 96 lt1 cam dowel pin
You can cut it or tap it in. .30 +/- .01
Old Apr 9, 2011 | 09:41 PM
Engine: 350 tpi
So I can just hammer it in? What's ther correct length suppose to br want to make sure I do it right
Old Apr 9, 2011 | 09:51 PM
watajob's Avatar
Car: 92 T/A 'vert
Correct. Use a soft mallet of some type so as not to "mushroom" the end of the dowel. Cutting is acceptable, just a little more difficult. Either way, it needs to protrude .30" +/- .01" BTW, an LT1 cam is a popular upgrade for a 305. It has a pinch more lift and duration than an L98 cam.
Old Apr 9, 2011 | 10:18 PM
Engine: 350 tpi
Yeah I've heard that alt1 cam is a good up grade I just read about the dowel pin though I guess ill just terri to push it in some.....ikl just use a tape measure ha ha to be sure it goes In enough
Old Apr 10, 2011 | 03:04 AM
watajob's Avatar
Car: 92 T/A 'vert
A dig caliper would be the hot set up.
Old Apr 10, 2011 | 11:00 AM
Engine: 350 tpi
OR that ha ha thanks for the help I appreciate it
Old Apr 11, 2011 | 10:50 AM
Engine: 350 tpi
can this be done with the cam in the motor already and just real it til it clears the timing cover?
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
gixxer92
Sep 1, 2015 04:32 PM
midge54
Aug 29, 2015 09:51 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
