Setting Fuel Pressure
Old Apr 13, 2011 | 07:57 AM
vette_1989's Avatar
Car: 1987 Silver IROC-Z
Engine: 305 V-8 300HP LT1 Cam
Transmission: T-5 5-speed
I just got my rebuilt 305 TPI engine running last night, but need to set the fuel pressure on my new adjustable fuel pressure regulator. The engine is basically stock with a LT1 cam and shorty headers. What should I set the fuel pressure at? I am going to install a pressure gage off the Schrader Valve tonight.
Old Apr 13, 2011 | 08:03 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Setting Fuel Pressure
I would go with 5psi over stock. Thats about 50psi. You really need to watch fuel trims to know if your setting is right. If the setting is okay, long term fuel trim(Block Learn) should stay neutral at 128.
Old Apr 13, 2011 | 08:47 AM
vette_1989's Avatar
Ok, I don't know what a fuel trims is, and how do I check for them?
Joe
Old Apr 13, 2011 | 12:07 PM
vette_1989's Avatar
http://www.srtforums.com/forums/f87/explanation-fuel-trims-here-229511/
Well I should have done some research before I left the above message. Above is a good explanation of Fuel Trims.
Thanks,
Old Apr 14, 2011 | 07:46 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Good job doing your homework.
Old Apr 14, 2011 | 04:35 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
All you have to do to install your AFPR is, first find out what the stock setting is on your car via fuel pressure gauge. Then install your new regulator. Then disconnect regulator vacum hose and plug it. Hook up your gauge and start the car. Then you would adjust it at idle. As another member stated 50 psi is about the max you wanna go. I suggest just going up a couple of pounds from what your stock setting was at first. A pound makes a big difference also.
Old Apr 14, 2011 | 05:16 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Don't be concerned with fuel trims as your adjusting initial fuel pressure. You will not get an accurate read at idle with no vacuum to regulator. Set base pressure, I actually do this with the FP relay jumpered to run with the engine stopped. Then check running pressure with and without vacuum to regulator to verify proper operation. Now, drive vehicle and monitor Block Learn(Long Term Fuel Trim) while you drive for 10-15 minutes at various speeds and loads. If Block Learn is 128, you are good to go. If Block Learn is higher, raise pressure 1psi, drive and recheck. If BL is lower, reduce fuel pressure 1psi, drive and recheck. Repeat this until Block Learn shows 128 after 15 minutes of driving at all load and speed ranges.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
