Can i put NOS on a 88 tpi 305
Old Apr 10, 2011 | 05:44 PM
1988TransAm22s's Avatar
Car: 1988 TRANS AM procharged
Engine: 305 procharged TPI with 5 speed
Transmission: 5 speed
Axle/Gears: 3:73
I have a 88 tans am with a 5 speed with many upgraded parts and i want a little more power... My question is can i run a 50 shot of nos to get a little more power without causing bad problems with my motor...I dont plan onm using it very much but would like to have it if i need it...Please give opinions on what you think b4 i order my NOS kit....Thanx John
Old Apr 10, 2011 | 05:56 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: Can i put NOS on a 88 tpi 305
I have had a 150hp shot on my stock 88 IROC tpi 305 for 15 years with no problems. The motor now has a 104k with still full compression. Just make sure you run a wet kit like the NOS 5151. You have problems with the dry kits. 50hp shot is to small and you will barely notice it. Start with a 100 shot. I don't even think you can buy a 50hp kit for tpi.
Old Apr 10, 2011 | 08:18 PM
Axle/Gears: 3:73
I tried looking online for a nos 5151 kit but i cant really find a real place in ther usa...Does any one know of someone that is selling a used set up that i could buy...if so pm me
Old Apr 11, 2011 | 10:44 PM
burnout88's Avatar
Car: 88 IROC
Both Summit Racing and Jegs stock the systems. They are biggest hi performance parts distubutors in America.
http://www.jegs.com/i/NOS/741/05151/10002/-1
http://www.summitracing.com/parts/NOS-05151NOS/
Old Apr 12, 2011 | 06:49 PM
Axle/Gears: 3:73
yea i found quite a few different places after i found out the part number was 05151... looks like its something im gonna order next week...I found this one on ebay item number 370185859728 its brand x is this simialar to the 05151 or different.. no big deal if the 05151 is better ill just get that one...Just wondering
Old Apr 14, 2011 | 09:11 AM
burnout88's Avatar
Car: 88 IROC
If this is the kit you are looking at it is junk
http://cgi.ebay.com/ebaymotors/ws/eB...728+&viewitem=
Look closely there is no throttle body plate just some chessy spray nozzle that I am guessing they will tell you punch a hole in the intake track to insert. On a MAF car I would always run a plate system!! Get the NOS kit!
Old Apr 14, 2011 | 06:14 PM
Axle/Gears: 3:73
ok one more ?... I found a buddy that has a Nos Sniper kit number 07005nos... he doesnt want much for it but he has a few xtra jets and some other parts for it...Is this a kit i could use or should i just stop trying to save money and get the kit above that you mentioned
Old Apr 14, 2011 | 11:15 PM
burnout88's Avatar
Car: 88 IROC
You want to blow up your MAF sensor and intake track use the sniper kit. It's the same junk with no plate for the throttle body. It's cheap for a reason.
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
