TPI gaskets?
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
TPI gaskets?
I remember on a past thread someone saying about what would be a good gasket set for modified TPI's (larger I.D's for the intake to runners and runners to plenum.) Anyone know where the thread is, or just what you guys have used? Also did any of you have to modify the gaskets? If so what did you have to do to make it work, and has anybody tried to make their own gasket set for the runners?
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: TPI gaskets?
http://www.summitracing.com/parts/EDL-3866/
http://www.summitracing.com/parts/ACC-74195G/
http://www.summitracing.com/parts/MRG-146/?rtype=10
If you get to big, you can use a hi temp rtv product but have fun removing .
Car: 1988 IROC-Z28
Re: TPI gaskets?
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
Re: TPI gaskets?
ive used it before and aslong as you put enough on there it never leaks, and lasts about 8 years
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
