TPI Block Sensor?
Old Apr 15, 2011 | 11:49 PM
vette_1989's Avatar
Car: 1987 Silver IROC-Z
Engine: 305 V-8 300HP LT1 Cam
Transmission: T-5 5-speed
TPI Block Sensor?
On the driver's side of the block on my 1987 TPI V-8 there is a sensor that looks like the Knock Sensor of the passenger's side (it takes the same kind of connector as the Knock Sensor). It is down low, toward the rear of the block. Someone has rewired this sensor, and I can't seem to find it in my GM Electrical Manual. What is this sensor for?
Old Apr 16, 2011 | 08:38 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
Re: TPI Block Sensor?
Im not sure if this is what you are asking but my 305 knock sensor was on the passenger side down low. My 90 5.7 engine has the knock sensor on the driver side. I had to lengthen the wires to make it reach.
Old Apr 17, 2011 | 07:26 AM
vette_1989's Avatar
This is a 305 engine, would there be dual knock sensors on this engine?
Old Apr 17, 2011 | 05:39 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
TPI has only one KS
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
