TPI swap, harness help needed
Old Apr 29, 2011 | 08:26 PM
73GREENMACHINE's Avatar
Hey everyone! I got a complete 1990 camaro tpi intake, harness, ecu and the rest of the car. So I have modded the intake to fit a classic SBC and now I'm doing the harness. I wand to eliminate everything that I don't want or need off the harness to make the engine run and shortin it so I can mount the ecu I'm the engine bay on the fire wall inside a box I made. So I want to cut off everything off except the tps, iac,ats,cts,map,knock sensor, distributor and coil wires ect and delete the vss,vats and all somg, ac and other none engine management related systems. A diagram would be awsome please help.
Old Apr 29, 2011 | 11:42 PM
Re: TPI swap, harness help needed
Anyone with a stand alone diagram? this is my first time playing with efi.
Old Apr 29, 2011 | 11:58 PM
Vaughjw's Avatar
You may be able to find the diagram on the internet, some of the years are listed but I haven't been able to find the diagram for mine yet.
John
Old Apr 30, 2011 | 01:11 AM
I have been searching, been to thunder chevy and other sites and have a bunch of diagrams but what I don't know is if I can jus cut off the wires that don't run the engine such as the smog stuff? Cand I just mark all the engine management sensors then cut all the wires then just wire the engine management wires back in? Why hasn't someone come up with a diagram yet? When I finish this project I'm going to post a thread on how to convert a factory harness to a stand alone with a detailed diagram so we don't need to pay other people to do it.
Old Apr 30, 2011 | 01:53 AM
Vaughjw's Avatar
I have read on this site before that many owners do cut no essential wires off and cap them. They they get a prom that doesn't use those circuits anymore.
I would cut the wires off and loop them over put some liquid electrical tape on them and then heat shrink them with white heat shrink so you can write what the wire was on the heat shrink. Then tuck them back into the loom.
Maybe someone on here can post a picture of the diagram you need.
Old May 3, 2011 | 03:52 AM
Vaughjw's Avatar
I found some diagrams on Autozone's website
midge54
Sep 2, 2020 07:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
jharrison5
Aug 19, 2015 05:53 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
