Running issues 91 Z28
Old May 9, 2011 | 12:40 AM
WarsaW08's Avatar
Car: 1991 Camaro Z28
I have a 91 Z28 350 TPI. Its having some running issues as far as accelerating to a higher speed and hesitating and occasionally the Check Engine light will come on. I've changed the fuel pump, fuel filter, new distributor, new plugs, new wires, cut the cats off and got new exhaust. I've tried to time it but I would always line up the mark right on zero, then unplug my battery and plug up my computer again, but I'm afraid i might be timing it wrong and that something else might be wrong as well.
Let me know what I might need to do to get it running smooth.
Old May 9, 2011 | 11:20 AM
hairysox33's Avatar
Re: Running issues 91 Z28
https://www.thirdgen.org/settingtiming
You time the engine's base timing with the EST connector unhooked. The ECU electronically advances the timing, and you will not be able to correctly time it with the EST connector hooked up.
The EST connector is right here-------->
Time to 6* BTDC (Factory Spec), not 0* as you specified.
Old May 9, 2011 | 12:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Pull the SES codes - grab a paperclip and read: https://www.thirdgen.org/service-eng...ht-error-codes
Old May 9, 2011 | 10:17 PM
WarsaW08's Avatar
Ok, so I did the timing this morning and its perfect. What you said really worked, thanks. But it has a miss in it somewhere..
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
jklein337
Sep 19, 2018 06:23 PM
mizz0313
Aug 12, 2015 06:45 AM
