Expectations...
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Expectations...
Engine:
AFR 180 CC Street Heads
COMP Cams Ultra Pro Magum Rocker Arms in 1.6
COMP Cams High Energy Hydraulic Lifters (retro-fit)
Comp Cams Two Piece Aluminum Timing Cover
TPIS ZZ409 Camshaft
TPIS Big Mouth Manifold
ASM Large Tube Runners with Nitrous Port
ASM Ported Plenum
ASM 52mm Throttle Body
TPIS Adjustable Fuel Pressure Regulator
TPIS EGR Block Off Plate
MSD Super Conductor Wires in 8.5mm
Cardone Select Distributor
CSR Electric Water Pump
Tuff Stuff Performance 140 Amp Alternator
Exhaust:
Hedman Long Tube Headers
Hedman Header X-Tentions
Custom Y Pipe
DynoMax Exhaust System
Suspension:
UMI Double Adjustable Chromoly Panhard Bar with Rota-Joints
UMI Double Adjustable Chromoly Rear Lower Control Arms with Rota-Joints
UMI 22mm Chromoly Rear Sway Bar
UMI Cast and Camber Plates
UMI Front Steering Brace
UMI Lower Control Arm Relocation Brackets (Bolt In)
Blisten Front and Rear Shocks
Eibach Sportline Lowering Springs
Transmission: B&M Tork Master
Drivetrain:
Aluminum Drive Shaft
9 Bolt Rear End
T/A Performance Differential Cover
Tires: Federal 595 245/50/16R All Four
TPIS ZZ409 Camshaft
ASM Ported Plenum
Exhaust:
Custom Y Pipe
Suspension:
Drivetrain:
9 Bolt Rear End
Re: Expectations...
This is the engine with everything but the AFR 180 CC Street Heads, TPIS ZZ409 Camshaft, COMP Cams High Energy Hydraulic Lifters, COMP Cams Ultra Pro Magnum Roller Rockers...
The Car is currently at Cottrell & Sons Motorsports recieving the above mentioned parts along with a Timing Chain and Timing Chain Cover.
The CSR Electric Water Pump has since been put in.
Tuff Stuff Performance 140 Amp Alternator is sitting at home.
Re: Expectations...
Well I attempted to participate in the Dyno Day Event on Nov. 19th 2011. I was unable to Dyno due to no Connection/Communication between my vehicle and the computer used for tuning. Quite unfortunate due to the fact that I had to tow my car in...
Re: Expectations...
Who can help me get my car running???
Re: Expectations...
The guy there mostly does Carburetor's.
He doesn't do EFI tuning.
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
Re: Expectations...
Engine:
TPI 5.7L/350"
ASM 52mm Throttle Body, ASM Ported Plenum, ASM Large Tube Runners, TPIS Big Mouth Manifold
AFR 180cc Street Heads, 1.6 Rocker Arms
TPIS ZZ409 Camshaft 226/226 .512"/.512" LSA 112, (retro-fit)Hydraulic Roller Lifters
TPIS AFPR (Adjustable Fuel Pressure Regulator)
Exhaust:
Custom Y Pipe
Drivetrain:
2400 Stall by B&M, 700-R4
9 Bolt, T/A Performance Differential Cover
Tires: Federal 595 245/50-R16 All Four
TPI 5.7L/350"
Exhaust:
Custom Y Pipe
Drivetrain:
.. A couple more fascinating and informative EFI/TPI articles:
http://www.hotrod.com/techarticles/e...s/viewall.html
http://mpikas.blogspot.com/2008/08/t...june-2000.html
Re: Expectations...
Any information as to a reputable shop with adequate skills would be greatly appreciated...
Re: Expectations...
I'm going out to FAMOSO in Bakersfield, Any Idea's on Approximate Quarter Mile Times???
Re: Expectations...
Needs a Formal Street/Dyno Tune, I'm putting the Alternator on slowly but surely. Needs wiring for the Alternator. I discovered the flexplate has a couple Bad Teeth, so that might be a setback...
The Front Strut Brace and LCARB have not been installed...
I'd really like to run it once it's running....
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Expectations...
sound like a bad ecm,i had the same issue. car ran great,,just could never get a connection when trying to dyno-tune
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: Expectations...
only tuner locally is kevin, you should pick up some tuning gear, start with a close enough bin from moates and try and tweak from there.
Re: Expectations...
The battery was relocated to the Spare Tire location, in the trunk. The cable that connects to the starter needs to be replaced. Unfortunately it it's really thick and runs all the way to the back to the battery. The three wire plug that connects to the Alternaror needs to be extended as the Alternator now sits on the Passenger's side as opposed to the stock location which was on the driver's side. There's also a couple of loose Cables that need to be addressed...
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: Expectations...
Re: Expectations...
Who else besides Kevin Lorentzen is tuning TPI's here in So Cal...
Re: Expectations...
Okay, I finally gave in, Street Tune on Sat, June 23rd with Kevin Lorentzen.
I have a chip from TPIS that I will save for the next Dyno Day, for comparison.
Should be interesting...
