help with air filter
Old May 15, 2011 | 09:19 PM
go88iroc's Avatar
Car: 1988 iroc-z red 5.0 tpi
hi yea i installed this k&n RC-5000 air filter on my tpi and the car is having a rough start but if i put the regular filter on with the MAF sensor on it and it started up fine is it because the MAF sensor isnt hooked up or what please help tryna get more horse power out of it.
[IMG]file:///C:/Users/rudy/AppData/Local/Temp/moz-screenshot.png[/IMG]
Old May 15, 2011 | 10:13 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: help with air filter
First of all, if you have the OE engine management system with MAF, your car will not run correctly with the MAF unplugged. Secondly, that filter picks up hot air from the radiator and is far from ideal. If you want to increase air flow into the TB, do a search for "high flow air lid" to see how we modify our air filter lids to make them move some serious air. Look closely at my avatar for a clue.
Old May 15, 2011 | 10:58 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If you're looking for more power, skip the K&N air filter and look elsewhere. Just use a paper filter.
The oil in those filters will coat your MAF sensor and cause it to read incorrectly.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Thornburg
Sep 1, 2015 03:39 AM
