Passenger side breather hose
Old May 24, 2011 | 03:01 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
I am currently cleaning up the engine bay on my 89 Camaro 5.7. The molded hose that runs from the upper fitting on the throttle body to the passenger valve cover breather grommet was dryrotted and crumbled apart. I have gone to the parts store and tried a few different hoses, but none are working out correctly. the TB nipple is huge and the nipple on the breather elbow is significantly smaller. Does anyone know a remedy to this? I know I cannot just put in an open element breather because it "lets in unmetered air from the maf".... so what do I do.... right now i have a piece of hose thats freaking huge just shoved into the valve cover grommet..... is there a part number for the OEM formed tube??
Old May 24, 2011 | 05:17 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: Passenger side breather hose
nevermind... figured it out....
Old May 26, 2011 | 04:47 PM
88Roc-z's Avatar
Car: 88' Iroc-z
Transmission: T-5 WC
Axle/Gears: 3.73 9-bolt
So what did you do? I have the same problem..
Old May 26, 2011 | 07:57 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Me to
Old May 26, 2011 | 08:28 PM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Mine actually has a small length of steel pipe connected to a longer steel pipe connected to a small length of rubber hose connected to the TB. But I don't see why a simple length of rubber hose won't work with the proper fitting on the valve cover.
Old May 27, 2011 | 01:11 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
I ended up using just standard rubber fuel hose and routed it under the intake plenum and used a reducer adapter for the 90 at the valve cover.... really cant see much of it anymore...
Old Jul 2, 2011 | 10:03 PM
galletti's Avatar
Car: 1988 IROC Convertible
I found a pretty good explanation on the unmetered air issue but, is there a way to get around this when programming a custom chip? I'd like to delete this hose if possible.
Old Jul 2, 2011 | 10:19 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Can't delete that hose. PCV system needs fresh air supply.
Old Jul 2, 2011 | 10:33 PM
galletti's Avatar
Thanks. Thought so. I guess I'll have to find a way to make it look better.
Old Jul 3, 2011 | 02:22 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Actually you can, just cap it off at the TB and run an aftermarket breather filter. A cheapy from vatozone works great.
New2Chevy
Sep 28, 2015 12:35 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
