454TPI? is it possible?
Old Jul 2, 2011 | 12:29 PM
red/white04's Avatar
Car: 88 IROC
Engine: 305TPI
Ok, I'm in the middle of a 355 build and the intake i'm going to run is a weiand stealth ram... thing is they make a base that bolts to a big block. So could you used a tpi computer and harness to run a big block? I plan on building an old 60's impala(kinda needs a big block, they are heavy)...I'm very intregued by this..anybody done this? thoughts?
Old Jul 2, 2011 | 12:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 454TPI? is it possible?
No reason why you couldn't.
Old Jul 2, 2011 | 10:57 PM
mikespeed's Avatar
Car: 87 IROC
http://www.summitracing.com/parts/ACC-74202B/
http://www.summitracing.com/parts/ACC-74202P/
I would guess the install would be like that of an HSR,...
Old Jul 3, 2011 | 01:18 PM
Car: 88 IROC
Engine: 305TPI
anybody done this?
Old Jul 3, 2011 | 03:53 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
GMs been doing that with the Ram Jet 502 for years. Well not exactly, but pretty close
Old Jul 3, 2011 | 04:25 PM
Car: 88 IROC
Engine: 305TPI
thinking of more of a budget fuel injection then ram jet...i have may extra wiring harnesses and computers laying around. just curious if anyone has done this..i'm sure im not the 1st to think of this.
Old Jul 3, 2011 | 04:28 PM
luvmy64's Avatar
Hi-flow injectors.....customized chip....go for it. Burning your own chips/datalogging would be the only way...
