High/Stuck Idle
Old May 25, 2011 | 10:04 PM
Iroc 87's Avatar
Car: 1987 IROC Z28 Camaro
Transmission: Stock
Axle/Gears: Stock
High/Stuck Idle
87 350 TPI. During warm up even after motor is warm 190-220 Temp, i have a sticky throttle? While driving 35mph if i let off the gas completely, the car still goes 35mph at the same rpm, like it was on cruise control? If i put the car in neutral and rev it up the rpm and throttle go back to normal operating, whats going on anyone have a similar problem?
Old May 29, 2011 | 01:43 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: High/Stuck Idle
Sticky IAC/linkage?
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
